Manually Decoding Silverado VIN to Trim Level
Hello,
I have used this forum to decode 2016 Silverado's and it worked great. However all I need is to figure out the trim (1LT or 2LT, 1LZ or 2LZ, WT or LS). Is there a way to manually decode a 2016 Silverado VIN down to it's trim level based on the VIN? Any help is appreciated, Thanks |
Originally Posted by gueed9
(Post 317204)
Hello,
I have used this forum to decode 2016 Silverado's and it worked great. However all I need is to figure out the trim (1LT or 2LT, 1LZ or 2LZ, WT or LS). Is there a way to manually decode a 2016 Silverado VIN down to it's trim level based on the VIN? Any help is appreciated, Thanks Check the RPO code decal, usually found in the glove box. All RPO codes can be decoded at this link. https://d354nuoz4t18d4.cloudfront.ne...m/rpoCodes.pdf |
