2002 chevrolet astro blower motor problem
I have a 2002 chevrolet astro van and my front blower motor is not turning on. I recently replaced my blower motor and have checked it with a wire to the battery and it turns on.. I also recently replaced my resistor and bought a used climate control switch.. i took a test light to the wiring harness that goes to the resistor and all the speeds light up but the thick orange wire that everyone says is suppose to be hot all the time is not.. does anyone no what the problem could be?
Ok so I took a new 12 gauge wire and spliced into the the fat orange wire at the wiring harness and under the 30 amp fuse under the hood and now I have high heat! But not the other temps.. but like I said the temps worked at the wiring harness so I'm guessing my resistor also went out and will be trying that for the other temps later
