astro 1997 van rwd
astro 1997 van rwd
i GOT FINALLY THE FUEL PUMP CHANGED SECOND TIME IN LESS THAN 30,000 KMS, THIS TIME IT IS AC DELCO ONE, COST ME $800 TO GET THIS INCL LABOR, WHAT IS BEST WAY TO DRAIN THE COOLANT IN RAD AND PUT THE NEW DEXCOOL BEFORE IT IS TOO HOT AGAIN, I CHANGED MY COOLANT BACK ABOUT6-7 YRS AND HAVE ABOUT 100,000 KMS AFTER THAT . PL. SHOW PICTURES TO LOCATE THE DRAIN ETC. AND QUANITY TO MIX THE COOLANT WITH WATER SO IT DO NOT GET ANY PROBLEMS FOR WEATHER LIKE IN TORONTO DURING SUMMER & EXTREME WINTER.
THANKS IN ADVANCE!!!
My sources show the same radiator being used 1996-2005. I just checked on Green, the radiator drain is located below the lower radiator hose on the passenger side. Either push some hose onto the drain tube or place a bucket under it, then turn the handle to drain.
