Can't identify a sensor on engine block that is cracked and needs replacement
If you are inside the van, it is on the left side of the engine block, above the spark plugs, and is blue. The harness for this sensor goes over the engine, then back down to the back by the distributor, combining with several other harnesses. I have a photo o the sensor, but I'm not sure how to post it n this forum.
There's a map sensor just under the top hose on the bulkhead, a bit difficult to get to. other sensors on the air intake tube can be cleaned with an air flow sensor cleaner spray, available on Ebay or Amazon. videos on YouTube.
AstroBoy94
May 20th, 2017 8:41 PM
