engine and abs lights coming on ????
i have a 93 astrovan 4.3. the abs light and the service engine soon light go on and off intermittently. i have the code reader and it tells me that the ecm code is
"#43 electronic spark timing (EST) circuit - low voltage detected / electronic spark control (ESC)- circuit problems". and the abs fault is "#8 shorted dump valve circuit or faulty ecu". both these lights started coming on within a day of each other...i kinda sounds like maybe something is not putting out enough voltage or something. any ideas what it could be??... thanks |
RE: engine and abs lights coming on ????
I HAVE THE SAME W/A 1993 CHEVY S-10 BLAZER. WHAT YOU FOUND HAVE
| All times are GMT -5. The time now is 8:12 AM. |
