Engine Fan Removal
My service manual for the 96 Astro 4.3L engine tells me I need a special removal tool for the engine fan/clutch assembly. Where can I get this tool - or is there an easy way to remove the entire fan assembly?
Welcome to the forum.:) You can rent the J tool or equivalent fan clutch wrench from some parts stores. Without it there's no way to keep the water pump pulley from turning.
Thanks....appreciate your time and knowledge :)
You're quite welcome.:) Hope it works out for you.
I don't use a special tool. I use a big ol adjustable wrench and a large box end wrench (usually grab the 20mm).
The box end is placed over one of the four bolts for the water pump pulley in position to pull the pulley clockwise thus keeping the pulley from spinning and the adjustable is use the the big nut to turn the fan assembly count-clockwise. |
Thanks for the update...now I don't have to rent the "special" tool (aka spanner wrench)...water pump replacement went well...210k miles daily driver should last for another 150k :)
Fan clutch
Originally Posted by RobertShumaker
(Post 194522)
| All times are GMT -5. The time now is 1:03 AM. |
