Rough Acceleration
'99 Astro Van
~95K. New Battery Rebuilt Trans New Plugs/Plug Wires Wonky Gas Gauge Shot Vacuum Lines I've got a problem with my Astro Van that I could use some help with. This van idles fine, but from a stop to around 30mph, I get some noticeable acceleration problems. It feels like a miss or sputtering and seemed to be just before hitting 2nd and 3rd. It doesn't do it every time, but it's most of the time. It may do it a little when cruising ( could be my imagination), but is more common when accelerating from a stop. I'd appreciate any help. This is my work van and I need to keep her on the road. |
Might want to check the transmission. mine did the same thing before i had to replace it. go ahead and get it serviced.
Originally Posted by fufurifraf
(Post 203460)
ah sorry i didnt see that.its probably something with your fuel intake.
Finally saw a code today. P0300 : Multiple/Random Cylinder Misfire
Think I'll replace Dist. Cap Monday. |
Replaced Distrib. cap Monday and the Astro is running great. Took it out first thing this morning and no problems! May have solved this one (knock on wood).
**update: 7 days and no problems... |
I am having the same issues with my 1999 Chevy Silverado 1500 4.3L. Runs smooth at idle, but when go to accelerate while in park It feels like a miss or sputtering. The truck has new fuel filter, dist. cap, wires, plugs, and air filter. I am at a loss.
I want to make a note....no check engine light on and no codes.
