Audio/Visual Electronics Wired up? Got a cool sound system? Discuss all your Audio, Video, and other cool electronics here! Please limit the contents to aftermarket only. If you have questions that pertain to a certain model, post it in a model-specific section.
2002 Trailblazer Stereo Help
Old December 31st, 2009, 8:23 AM
sd7329's Avatar
Default 2002 Trailblazer Stereo Help
I have a 2002 Trailblazer that is having intermittant problems with the factory radio/CD player. Some days it will work fine with no problems. Some days it will only work with the tweeters in the front speakers. Some days it will only work with one speaker. This is very frustrating! I would just buy an aftermarket radio but want to make sure that would fix it. If there might be an existing seperate amp that is malfunctioning then the aftermarket might not fix it. Any ideas on what's going on? If you need any more info let me know.
Thanks.
Scott
Old January 12th, 2010, 9:18 AM
AndrewSE's Avatar
You may have a short in the harness or it is possible the plug has become loosened from the back or has corrosion on it.
No way to tell for sure unless you take it out.
Volt meter is your best friend when diagnosing electrical issues with car stereo wiring.
Old January 12th, 2010, 8:55 PM
Banned
shawnvw's Avatar
do you have a bose system? it will say bose on the front door speakers and you will also have little speakers in the dash.
Old January 28th, 2010, 6:24 AM
sd7329's Avatar
I ended up taking it out to replace it with an aftermarket unit. The original was not a bose system. There were no signs of corrosion or loose connections that I could find. I installed the aftermarket one and it works great! Must have just been the original head unit itself was going bad. Thanks for the help.
Scott
Old January 31st, 2010, 12:53 AM
JamyElson's Avatar
Default Hi
Honey why dont you try out Audio Pro Stereo Zero its a very hifi sound system. My cousin has fixed it in his car and it rocks. you can read its reviews at http://www.testseek.com/home_electro...b310673ea.html if you like but I really enjoy listening too rocking music.
Old September 2nd, 2015, 10:02 PM
Mary Jane Fabisch's Avatar
Default 2002 trailblazer radio, cd player help
My 2002 Radio/Cd player is locked in the CD mode and will not change and I cannot eject CDS.. What could the problem be?
davet
February 17th, 2022 8:08 PM
trucknoob45
August 16th, 2014 8:16 PM
Sweettaz88
September 28th, 2012 11:13 PM
cube4hire
Silverado & Fullsize Pick-ups
May 8th, 2007 9:03 PM
Quick Reply: 2002 Trailblazer Stereo Help
