Radio to navigation upgrade
Hey I own a 2012 silverado crew cab ltz and I want to upgrade the stock radio for a in dash navigation screen. I bought one off a guy online, hey said it would work. I then took it to the gm dealer and after an hour with the truck he said it would't work cause of software and it is only good for an early model 2011 avalanche or Tahoe.
Is there any thing I can do with this like reprogram or something?
you need to find someone that unlocks the radio and reprograms the radio to your system check your glove box the radio code is there and see if it match to the unit you purchase, if not it will need to be reprogram,
unlocks removes the old vehicle vin number and add your vin number
reprogram, is for the audio options in case you have bose or the vehicle configuration
here you can learn more
03 13 GM Truck Nav Radio Theftlock Unlock Programming Service Read to Learn More | eBay
For the radio to be unlock , they need the vin number for the new vehicle ? or it can be unlock and use in any vehicle, I have not decide where im going to use this Nav radio
