07 wheels and tires
Hi I have an 07 avalanche and put in a supreme leveling/ lift kit 3 inches in the front, I’m having trouble finding a place to have it aligned as I already ruined my front tires. I have 18 inch rims with 265 tires hoping to go up on the tires but not sure what should fit. Anyone know what I should do for either issue? Thanks |
when you run tires that are a lot bigger/wider than stock...the toe in should be increased over stock settings. .wider tires will toe out more running down the road so toe in must be increased to achieve zero toe when driving.
Originally Posted by tech2
(Post 357032)
