-   Avalanche (https://chevroletforum.com/forum/avalanche-18/)
-   -   Avalanche with tail light problem (https://chevroletforum.com/forum/avalanche-18/avalanche-tail-light-problem-1141/)
tubby32 Apr 12, 2006 10:05 PM
I have a 2002 and the drivers side rear tail lights dont work, the brake lights work, the turn signal works and the fuse is fine. I have replaced the bulbs with the right replacement bulbs but still no lights. I am only reading 10 volts to the socket and the passanger side reads 13 volts. any suggestions as to what my problem is and how to make my lights work
Nomad76lj Apr 24, 2006 6:47 PM
RE: Avalanche with tail light problem
sounds like u may have to replace the socket on that side just make sure if u do it yourself that you make it watertight.
viperjuice Jun 1, 2006 9:35 PM
sorry dude, i forget.. does the avalanche have circuit board by the taillights or separate socket? .. if it's circuit boards, try switching left to right..
also check for voltage at the socket but using a different ground and not the one in the socket, cause you could have a bad ground
