1988 corisca turn signal problem
Hey, I just got this corsica. Its in pretty nice shape. I replaced the bulbs that needed to be replaced, and i still have a problem. The front left, and rear right driving lights work when the headlights are on, but when the turn signals are on, neither the front left, or the back right work. I hear the clicking, but the dash lights dont flash on or off. Anyone had this problem, or can help me fix it?
Thanks |
so i laid my ninja on its left side and now my left front turn signal doesnt light up, but the left rear lights up but stays solid not flashing when the left turn signal button is turned on. whats wrong with it and how can i fix it?
The wireing harness mystery
I would take it to a good Firestone for a good electrical check. Sounds like you need some major wireing harness repaire. The wires insulation wares out and this might be the problem.
Hey, the problem was the tuenn signaln switch. If you have a problem like this, push in on the bturn signal lever to see if that fixes the problem. If you need your cars serial number, its the last six digits of the vin. Good luck
