No Brake Lights, Dash Lights, And Turn Signals
I do not have the following above. I have checked all fusses/bulbs and they are good. The flashers do work though. Are they related to the turn signal flasher or anything? I have also noticed that someone has opened the dash in the past. What do you guys recommend?
These things may or may not be related. You have to check everything one at a time. The brake lights could be caused by a bad brake light switch at the pedal or bad connection to the bulb at the socket. The dash lights also have a switch which over time sometimes stops working. It may take time, but check everything thoroughly.
I had some time to look at it today. When you try to use the right turn signal the bulb goes on for a brief moment. Is the hazzard flasher and the turn signal flasher the same? Also, there are some relays and fuses under the hood. Would they be related? If not what are they used for?
I don't think it is the bulbs/sockets. When I turn the flashers on with running lights they flash bright.
I have found out also that the air conditioning doesn't work.
I have also read else where that the turn signal switch could be the problem, is that possible?
ExBest182
October 5th, 2013 4:26 PM
GregHamilton
August 20th, 2013 12:05 AM
SIRIKSAA
November 13th, 2011 7:46 PM
