Misfire
Hi guy. I need some help. Having a misfire on cylinder 4 in my 2000 chevy blazer 4.3L 2WD. I have spark and fuel. Compression is only 60 psi. Not sure where to go from here.
Originally Posted by Olandjonathan231
(Post 456933)
(Post 456934)
60 PSI is way too low. How many cylinders? Have you done a wet PSI readout?
Misfire
It has 265000 miles on it. I've had the truck for 7 years. Fortunately I haven't had to tear the engine down that far yet. Tomorrow I am going to take the head off that side. If it is a burnt valve is there anything in particular that I should be looking for or any handy tips you recommend?
Misfire
Do you think running a couple cans of sea foam threw it might fix it?
(Post 456939)
Misfire
Thank you for the insight. I will hook the air supply to it and start there. When I am listening for the leak should where should I be listening and more over where should the distributer be pointed to a closed exhaust valve on cylinder 4?
Originally Posted by kevinkpk
(Post 456936)
Yep, way low. Might be a burnt valve. This if the case, is usually do to crappy gas.
ARCO (and cheap gasoline) Gasoline. Pay me now or pay me later, Junk gasoline that allows for deposit build-ups. Same with engine oil changes. Who in **** needs an oil change sensor. When its BLACK it's too late. Someone will be making money even if the OP does the work himself. (getting tired of all the female names men use here too.) |
(Post 456940)
Misfire
I will do the wet test today to see if its the rings. Can I change the one head now and the other later? Things are tight right now.
