2000 camaro engine swap
bought a camaro with a bad v-6 engine. going to drop in a carburated v-8 350 truck engine. i know that i will have to change out the tranny mounts, pulleys, belts, fuel delivery system and probably the driveshaft. am i missing anything else other than some cramming and wedging ?the truck engine is a gm goodwrench replacement for an '86 scottsdale. also not sure if the stock rearend can handle the extra power and the turbo hydromatic 350 ? any guideance or info would be greatly appreciated !
Welcome to the forum.
You'll have to change all of the accessory mounts. And don't forget all of the wiring harnesses and radiator hoses. Might need to put in a larger radiator. Ambitious project but doable. Good luck. |
Originally Posted by 73shark
(Post 341420)
