4.3 v6 into 1996 Camaro? Will it fit?
The car has a 3.8 in it now but needs a new motor. I would like to know if the 4.3 would fit without any problem? ThAnks for looking.
yes that car also came with a 5.7l v8 the 4.3 has the same basic width as the 5.7... will have to swap engine mounts and roll on
Originally Posted by PapaBurgundy7
(Post 175635)
I have a 95 chevy Camaro with the 3.4 motor that is throttle body so I know it will fit
Originally Posted by robertbartley
(Post 305717)
The 3.4 is a 60 deg V6 with multi point fuel injection. Yes like all fuel injected cars it has a throttle body on it but it not a throttle body injection system like the 4.3 has. You will not be putting a 4.3 in a 4th gen unless you are the kind of guy that can put v8 in a Chevette . Course if you are you would not e here asking if it is possible.
it might fit and then it might not ! if you want my advice your better off to drop a 3800 v6 in it ! a 4.3 might fit but too much changing around ! a 3800 v6 would be a better idea !
