Camaro wont start!
Camaro wont start!
I have a 3.1 V6 camaro, 1992 RS.
I have recently replaced the starter motor, then the battery. For some reason now, it will not start. What have i done? Can anybody help? Obviously, being in the UK is not helpful with issues like this so any help will be gratefully recieved...
All the best,
Hannah
All the best,
Hannah
Camaro wont start!
<FONT face="Verdana, Arial, Helvetica, sans-serif">DID YOU TRY THE ELECTRONIC IGNITION MODULE UNDER THE DISTRIBUTOR CAP ? BET THATS IT BEEN THROUGH THE SAME THING.</FONT></P>
<IMG src=smileys/smiley1.gif border="0">KRISPY BURNTCHA</P>
Camaro wont start!
</P>
<FONT color=#ff0000>.</FONT> Take a look at the ignition key. There should be a pellet on it. This is known as the VATS pellet. It's a anti-theft part. The ignition cylinders have very fine wires running down the column that break with the turning of the key. If one opens while you go to start, the PCM will look at this as an unauthorized start and shut down the starter and fuel. A dealer has a tool that hooks into column wires to check that this pellet is sending it's resistance value to the PCM. This is not to difficult IF you have the tools to take column apart. But if you have an airbag, better let them do it. There is an outside chance that the key is worn out as well. If you have a spare, try it first.<!---
<CENTER>
</CENTER></P>---></P>
excesss
Silverado & Fullsize Pick-ups
February 22nd, 2006 9:15 PM
beaverton007
November 14th, 2005 11:20 PM
