1986-1990 Caprice door panel removal
Seems impossible unless there is track. Pull handle is riveted to the door panel and a backing plate that is secured to the dorr with screws with no access unless you damage the door panel. I am sure there is trick to this. If you know it please let me know. Thanks
Remove arm rest. Drill out the rivets on the pull straps. Remove door panel. When reinstalling, simply re-pop rivet the pull straps back on or use screws.
Originally Posted by Free Safety
(Post 347704)
Taking the door panel off you use a plastic trim pronged fork to remive the plastic barbs. Good luck! |
