Brake problem
Hi, my son has a 1994 Caprice Classic 4.3v8. He asked me to look at his brakes, said the pedal is going to the floor after he made a hard stop. I thought that after 20 years that he blew a brake line or something. He brought the car up and I looked at the master cylinder and there was fluid in both resivours. I had him start the car and apply the brakes while I looked under the car for fluid. There was no fluid leaking. What do you think the problem may be? Brake booster?
-is the pedal going deep all the time or is it intermittent?
-does the pedal come up a bit if pumped repeatedly? -did the abs pump activate during the deep pedal? -does the brake fluid rise up in the master cylinder when the pedal is slowly pushed and held down? -did you inspect all the calipers and wheel cylinders? |
I didn't check the things you mentioned. I won't have time to look at it till Friday but will check these items. The ABS light has been on for over a year so the ABS is inoperative.
If you have no leaks , first thought is one or more of the rubber seals , in the master cylinder , gave way & is letting fluid past them . Instead of pumping the fluid , as it should ?
If that is the case , either replace the master cylinder . Or , you used to be able to rebuild them . Probably would need a brake cylinder hone & electric drill motor . I used to have a hone , but no telling where it is now ? I think there is also a pressure valve in the master cylinder , that holds pressure on the lines ? God bless Wyr |
Thanks for the help. I will check it out on Friday.
