1995 Cavalier Turn Signal Issues
So, I was looking for some suggestions on what I can do to fix my turn signals. They quit working on me. Not only do the signals themselves not turn on, but the little green arrow on the dashboard doesn't come on either.
I checked the fuses, even changed the one the blinkers are on even though it looked good, still didn't work. I changed the Turn Signal Relay, still didn't work I installed a new turn signal switch (assembly), still didn't work. My hazard lights work and the green arrows come on for the hazards too, but not the blinkers. I assume it's a wiring problem but dont' know where to start. Any suggestions? |
RE: 1995 Cavalier Turn Signal Issues
If it helps, it's a 2.2 liter and doesn't have cruise control.
I have 1995 also. With key on and if I put my turn signals on, it would only light up the back but not blink. In short I took it to a guy that found there ia a 2nd flasher up by the radio. The one down by the brake peddel is for the flashers. That solved my proplem. Good Luck
