2002 Chevy Cavalier A/C not working
2002 cavalier LS 2.2L automatic
the air conditioner is not working. i have taken the cover off the relay and manually closed it which causes the compressor to kick on and ice cold air to blow. i have swapped relays but the same issue occurs. |
is the refrigerant level low?
Originally Posted by tech2
(Post 359185)
Originally Posted by cbharless78
(Post 359192)
I believe levels are good, I will double check it this evening
Yes i agree. That is how we found out it was not working, I personally didn't check them because I don't know how but a family member who does minor service and has the equipment is the one who said everything was reading correctly.
(Post 359312)
How can you know the pressures are good unless you test them?
best bet if you have access to a machine is to recover the system...they you know with 100% accuracy the charge level....looking at pressures on a guage isn't the best method
(Post 359351)
