2003 Cavalier Starting problems!!!!
I have a 2003 Chevy Cavalier LS coupe, 2.2 ecotec, 5 speed. The other day I went out to start my car (I had driven it the previous evening without any issues whatsoever, so sounds, nothing) And it wouldn't turn over. You can hear the starter turning but it doesn't turn the engine over. You can hear the fuel pump priming when you turn the key in the ON position. I had the battery tested, pulled the starter and tested that (and while it was out I checked my fly wheel), and for the heck of it tried to push start it. Nothing worked, I checked the fuses and the fuel pressure, everything checked out fine. I replaced my spark plugs and even changed out the neutral safety switch. If anyone knows what the heck this could be any advice would be appreciated.
Thanks!!!! |
Does it have spark.
