97 cavalier
my engine light came on and the car started to idle rough
computer showed multple engine mis fire after tune-up,replacing coil packs and ignition module.it is still doing the same thing. can anyone help? |
RE: 97 cavalier
You might want to take it to a dealer and have them run a diagnostic. You don't have to have them fix it but you will pay somewhere in the neighborhood of 70 -100 bucks. I know the crank sensor isn't the fix all to every problem but if it is mis-firing it may just be the crank sensor which costs around $20.
RE: 97 cavalier
check your tps (throttle position sensor) and your idle air control sensor, and make sure all ur plugs are in tight
