98 Cavalier cold start problems
My 1998 Cavalier has a rather frustrating problem, whenever its left to sit for awhile it has a very long crank. If I restart it after a long crank it fires up immediately and will start immediately if left to sit for up to around 15 minutes, any longer then that and the long crank comes back.
I have noted a smell of gas after a long crank start. Car info: Year: 98 Engine: 2.2L 4 cyl Model: 4dr sedan, base trim Things that have been replaced: Fuel Pump, fuel filter, pcv valve, spark plugs and wires, crankshaft sensor and camshaft sensor. Other than that it runs nice and there are no other problems, but this long crank is pretty frustrating and probably not good for the start motor. |
the injectors may be leaking down into the combustion chambers. If the car starts better in clear flood mode (accelerator held to floor) check for injector leak down.
-install a fuel pressure gauge -prime the fuel system by cycling the key from off to run -note the fuel pressure -watch for pressure drop |
Originally Posted by tech2
(Post 253473)
After it has been sitting (when it would hard start) pull the vac line off the fuel pressure regulator to see if there is raw fuel inside the line.
