airbag light
airbag light is on. dont know why just bought the car at auction.
What year ?
The module for the air bag could be bad or the air bag is not present...knowing what year model will help.... |
oh its a 1999. if i were going to fix the problem instead of just removing the bulb, where would be the best place to start? i tested the fuses under the dash and the only one that was bad was the horn.
have the restraint codes read with full function scan tool and post the codes here.
did the horn work after fuse replacement? The horn control circuit must pass throught the clockspring as does the driver airbag....related??? |
Originally Posted by tech2
(Post 234955)
you were talking about the scan tool they use at the dealership right?
there are generic scan tools that can read airbag codes.
As long as the sensing and diagnostic module is ok; no programming at the dealer is required. Any shop could do the repair in that circumstance. Few people will give advice on a forum for airbag work due to the possibility of a deployment. If your not trained in airbag systems, have a professional do the work. |
(Post 235944)
| All times are GMT -5. The time now is 9:34 AM. |
