-   Cavalier (https://chevroletforum.com/forum/cavalier-12/)
-   -   Cavalier shifting problem (https://chevroletforum.com/forum/cavalier-12/cavalier-shifting-problem-55019/)
Gabety Dec 6, 2012 10:29 AM
I have a 1995 Cavalier with an intermitant problem. After the car has been running for some time, say 50 miles or better without being turned off, it will die at stops. As I slow the vehicle to stop I realized it was not down shifting. Killing as if it was a standard shift and not using the clutch when stopping. If you start it back up it runs fine but as soon as putting it in D it dies. If you use a little brake and throttle up you can get it to 1 gear and get underway again. As long as car remains at a suitable speed for the gear range it's in there is not problem running or shifting up, just down as you need to slow and stop.
Like I said you have to have driven the car for awhile before this would begin to happen. I had the transmission serviced and seemed to cure the problem for a time including on long drives. I did not mention this to my GM dealer when the trans was serviced and I thought that had cured the problem. Letting the car sit for a while, 15-30 minutes will allow "normal" operation again. I like to try with advice here to fix this myself it someone has suggestions. Thanks
