starting problem
have 95 cavalier, standard engine.
turn ignition switch, hear grinding and flywheel spin. it takes a while of turning ignition for the engine to "hit" and start running. a friend said it was the solenoid not giving enough power. haven't taken it off yet to have it tested. solenoid and starter are on bottom of engine. use a floor jack? Any feedback would be appreciated. Thank you! |
First off welcome to the forum!!!
Now your problem is your starter! Im not sure if the solenoid is seperate from the starter or if it is all one unit! But the starter should be on the passenger side of the engine block on the bottom! Can anyone verify this? |
removal procedure for starter on 2.3l & 2.4l
And welcome to the forum!! |
Thats what i thought. If it was a truck I would be positive, but I have never owned a car. Ive owned six trucks though! All chevys of course! Good luck Ahimsaman!
If you get a second stop by the Ride of the month and vote for this months winner! Simply click on the link in my signature! |
Originally Posted by suzuki-guy
(Post 97593)
Now your problem is your starter! Im not sure if the solenoid is seperate from the starter or if it is all one unit! But the starter should be on the passenger side of the engine block on the bottom! Can anyone verify this? Advance Auto sells them as a package deal. I found the starter in the front near the bottom. Seems pretty easy. Thanks again. Woody |
Originally Posted by Mike Sigmond
(Post 97602)
And welcome to the forum!! I found the starter in the front middle of the car. I traced the positive cable from the battery and it was easy to find once I looked good enough. Maybe my model is weird or something. It's a 2.2 regular motor. Again, thanks alot for the info. I'm changing it out tomorrow when I get paid! |
(Post 97616)
If you get a second stop by the Ride of the month and vote for this months winner! Simply click on the link in my signature! I may need all the luck and skill I can get. I've owned this car for a couple of years. Bought it and it only had 35k miles on it and it is 14 years old. I'm thinking since it wasn't used much there are some corroded parts that weren't put under much load. I commute with it every day. |
Glad we could help!:)
| All times are GMT -5. The time now is 7:58 AM. |
