sticky throttle
I have a 99 cavalier 4 dr with the 2.2 and 4 speed auto trans. recently I have put new plug wires , and replaced the water pump. Now the throttle has stuck a couple of times, what can I do to fix this problem? My wife is going to have my hide if I don't fix this.
Try to clean the throttle body with carb cleaner and a tooth brush. BG make a product specifically for that, it lubricates as it cleans. You maybe able to find something similar in the store. You could go to BG products website and find some where to get it.
make sure the floor mat or carpet isnt making it stick.. push in while u watch n see if its stickin whel u do it
Thank you very much for the common sense advise. I cleaned the throttle body, just so happens I had some throttle body cleaner, so far so good.
| All times are GMT -5. The time now is 8:23 AM. |
