Making me dumb founded
I have a 2001 S10 extended cab 4x4. I recently started having problems getting my pickup started. I put in a new battery, and starter but still having the problem.
Ok...when I turn on the key trying to start the pick up it just make a clicking (this happened the first time) sound. That's why I put in a new battery. Troubleshooted more and decided I need a new starter as I was thing that the solenoid was the problem. That was the reason for putting a new starter in it. I decided to charge the battery. All right. After all of the above I go to start it and I get on clicking sound and I loose all power. I could really use some help. Dale |
Originally Posted by Dale Wilcox
(Post 451075)
Check your battery cables at both ends as well as the connections. Also check the ground strap to the engine block.
I did and was able to start the pickup.
I would suggest you look at this license plate lookup, via VinPit here. I have many experiences in purchasing and selling used cars. This tool helps a lot for me to look at the history of an old car that is beneficial for purchasing.
| All times are GMT -5. The time now is 6:25 AM. |
