Fuel tank
Old April 28th, 2017, 5:20 AM
Homeboy 44's Avatar
Default Fuel tank
I have developed a vacuum in my gas tank as the level goes down. I am also using more fuel.
Old April 28th, 2017, 8:32 AM
did this occur after changing the tank or sending unit? If not, try replacing the fuel cap...older vehicles used vented caps that relieve pressure or vacuum.
Old April 28th, 2017, 4:21 PM
kevinkpk's Avatar
Yes, you probably will need a vented gas cap.
Old April 29th, 2017, 1:19 PM
Homeboy 44's Avatar
Thanks, I'll give it a try. Would be a cheap fix.
Old April 29th, 2017, 4:03 PM
Homeboy 44's Avatar
Replaced the gas cap, no change. Do you think the float could be stuck? I've gone from 15 mpg to about 4.
