07 cobalt won’t starter won’t roll over
i drrove the car parked it over winter went to start it battery was dead replaced battery but starter still won’t roll all accessories work an nothing dims just turn the key and nothing checked fuses also all good
there are 2 wires to the starter motor. one large from the battery. one small from the ignition. the small wire is power in start to close the starter solenoid. when closed, you should hear the solenoid click once. if you don't hear it click...check for battery voltage on the small wire.
It’s the BCM. You will get intermittent, starting problems with this problem.
This is is a common issue on this car and people end up spending hundreds chasing started and electrical problems.
Next time the car won’t start, give the BCM on the passenger side below the radio a kick. I becha it will start right up.
bcm can be ruled out in seconds. have someone turn the engine to start while you put your finger on the starter relay in the fuse box...if you feel and hear the starter relay click. the bcm is working normally.
