2010 Chevy Cobalt Lt, No start, Rapid Clicking, Dash lights flashing
Hello, my cobalt Lt stopped mid drive and wount start back up.
All it does when I turn the key is make the starter solenoid click rapidly, makes the whole cars electrical flash. It also unlocks and locks the doors rapidly. I changed out the battery, new starter 1 month ago. Here is a video of my issue: https://drive.google.com/file/d/1Xsal34lW_OIC7OREkjzj0WefkoxZqJdL/view?usp=drivesdk Any help? I think its maybe a grounding issue since it shut off mid drive going 25mph and the electrical is going crazy while trying to start. |
Sounds like a dead battery which could be caused by a bad alternator. Could also be bad battery cables or loose or corroded connections.
newfangled cars with no battery gauge :mad:
I have charged and replaced the battery and tried my spare battery to give the exact same symptoms.
I use my OBD2 adapter to see the battery voltage also and it's good well above 12. I cleaned the battery connections and they are perfect. No OBD codes btw. |
Check the battery voltage while trying to crank the engine.
