superfurn |
December 30th, 2016 9:43 AM |
2014 Cruze won't start after fueling
I have a 2014 Cruze that will not start after fueling. It does not matter whether I fill it or not. I have to pump the gas pedal to get it to start, and then keep the gas pedal depressed for about 2 minutes before it will stay running at idle. The check engine light is on, and the code shows lean condition in bank 1. The car has now started to stall at random times at stoplights. It starts using the same technique that I use after fueling. I have read every forum I can find to try to figure out what the problem is, and have found several different answers, including fuel injectors, fuel filter, vacuum leaks, and canister purge valve. I need to get the car inspected so I am wondering if anyone can point me in the most likely direction before I start just replacing random parts that I may not need.
