2016 cruze Lt window problem
2016 chevy cruze Lt. Window regulator broke on drivers side.. I replaced it with the same exspress up and express down .. programmed it and works fine up and down with exspress.. but now even though I didn't touch the door lock mechanism it sys door is open.. but if I open then close passenger door it says it closed.. or rolling window up or down makes door show its open.. so to be able to make interior lights go off I have to shut door then go open then close passenger door.. everything worked perfect befor the regulator install and didn't touch the harness except unplug and plug back inn.. checked all wires 5 times nothing pinched or touching window.. and display always shows roll window down then up constantly constantly u roll it up or down .. any suggestions?
Originally Posted by 265mercman
(Post 478368)
Yea I resent the battery left it unplugged.. left it unplugged for about 20-30 mins then had to reset the window again for express up and down and reset tps but still doing same thing
(Post 478388)
Did you get the right motor? I know there are two different plugs for the regulator. Maybe even though the plugs are the same the computer for those motors send different codes to the bcm on the CAN bus?
(Post 478368)
