2002 ls1 oil leak
2002 ls1 oil leak
I used the uv dye. Not coming from slot in bell housing. Its dripping from the starter bolt up high on engine. No oil from heads up. Drips down the joint between engine and belhousing. Some of the cross main bolts look wet but this starter area is dripping bad. Any ideas?
