408sbc insight
I’m looking at buying this 408sbc near me, it’s fresh build but I’m new to the engine stuff, I’m wanting to see feedback on this build and potential hp and tq it could make.... the build is as follows Sbc 408 just freshened up, only run time on engine stand and can hear run. 40 over 3.75 stroke. Dart SHP block King coated cam bearings King high performance main bearings. 010 over King high performance rod bearings. 020 over Mahle forged pistons w/ mahle rings Eagle crank Eagle rods Melling hv oil pump Comp extreme energy roller cam xr286r Comp roller lifters Comp magnum push rods Dart aluminum 180 cc heads 72cc combustion Holley high rise All arp bolts Motor is a 10.2:1 pump gas motor. Would be goin In my 66chevelle 300...th350 trans and 12bolt posi rearend |
The block sounds nice.. Get rid of the th350 an use th400..
