Engine Building & Overhauling All you ever wanted to know about building and rebuilding engines in here! Remember to post your model-specific questions in the correct section.
Bearing issue.
Old January 6th, 2019, 9:05 AM
andrews941500's Avatar
Default Bearing issue.
I was putting together my short block and noticed these Mark's on my bearings, I can feel it with my finger nail. Do I nee a new set of bearings?
Old January 6th, 2019, 12:45 PM
Kazoocruiser's Avatar
Location: Currently the Candian Gander is wintering over in New York.
If you are rebuilding a short block, why would you use questionable parts. Any advice here will be worthless if they fail. You'll feel bad, and maybe blame anyone who offered the idea to re-use marginal parts. The back side of the bearings are supposed to carry size stampings. The front side should be without divots, cuts, or other visible damage.
My .02.
Old January 6th, 2019, 4:44 PM
The bearings are fresh out of the box and this is my first rebuild so I'm being extremely cautious. Also did the picture I attached show up?
Old January 6th, 2019, 5:46 PM
I didn't see your picture.
Did you have the crankshaft machined? Did the shop supply you with the bearings?
Old January 6th, 2019, 6:32 PM
The crank was machined .010 over and I ordered .010 over Clevite bearings.
