Chevy C10 Cam Recommandation
Hi everyone !
I am currently rebuilding a 283 bored .030 over for a 1985 C10. (3.42 rear end/29'' tires/Muncie SM465
The engine is completly rebuild and ready to assemble
Heres are the spec;
-Stock unported Brand new Vortec head from GM (yes i know they won't handle past .475 lift)
-Around 9.5:1 compression
-Dual plane slightly raised intake
-Rochester Q-jet Carburetor
-Single Exhaust ''log'' manifold for now but will be going to header and dual eventually.
-Redline will be 6k
Its mostly ready to assemble but i've been battling for several months on what cam I am gonna put in this thing.
Im not sure yet if I will retrofit it to a roller cam (Reliability) but I would like to.
I boiled down to these following cams what you guys think about that ?
-LUNATI STREET MASTER 272/282 HYDRAULIC ROLLER
COMP CAM HYDAULIC FLAT TAPPET CAM 260H
12-206-2 [49]
Duration @.050: 212in/212ex
Lift: .440in/.440ex
LSA;110
COMP CAM HYDRAULIC FLAT TAPPET CAM XE256H
12-234-2
Duration @.050: 212in/218ex
Lift: .447in/.454ex
LSA;110
If you guy have better idea from past experience or personnal knowledge fell free :P
Heres are the spec;
-Redline will be 6k
- Advertised Duration (Int/Exh): 272/282
- Duration @ .050 (Int/Exh): 206/216
- Gross Valve Lift (Int/Exh): .447/.447
- LSA/ICL: 112/108
- Valve Lash (Int/Exh): Hyd/Hyd
- RPM Range: Idle-4800
12-206-2 [49]
Lift: .440in/.440ex
LSA;110
12-234-2
Lift: .447in/.454ex
LSA;110
