Engine Start Up
Engine Start Up
I rebuilt a 350 and stroked it to a 383, while trying to start the motor it spits up fuel from the carb, I then rechecked TDC on the #1 cyl and found that my timing was slightly off... corrected the problem and the engine started up, it ran smoothly for initial startup until i noticed a small fuel leak. shut the engine off fixed that, restarted the motor and broke in the cam, but now the engine wont start and it spits fuel out of the carb; we tried it again and got a nice little fire out the top of the carb. the dist. has not moved because it was tightened down. Any clue on what is causing or how to fix. Is a valve being stuck open or is the timing just so slightly off that it is causing this? Any help is greatly appreciated!
You say pushing gas back thru the carb? If it where an intake valve sticking, and pushing compression backwards, I'd still think it would run. What are the valve stem/guide clearances, actually did you have any problems with valve stem's too tight in the guides?
I put each cyl on its compression stroke, (both valves seated) then tightened the rocker til the push rod had some resistance then 1/2 turn more. I do not use roller rockers.
Valve Lash Adjustment
Hey guys, when you are ready to do your valve lash adjustments again, check out the new tool on the website below to help you do that. It's a magnetic vinyl strip with graphics that wraps around the harmonic balancer (temporarily) that shows you exactly where the camshaft lobe heels are at such that you can make your valve lash adjustments quickly and accurately.
ValveTrax
I have one for my Camaro Z28 and one for my C6 Corvette, works great! Just thought I'd let you know that something new is out there for valve lash adjustments.
ValveTrax
Thermool
Silverado & Fullsize Pick-ups
June 20th, 2009 6:41 PM
wildboy74ss
April 1st, 2009 5:10 PM
izod
February 14th, 2009 2:42 PM
larry_chip
June 2nd, 2007 3:20 PM
