Engine Building & Overhauling All you ever wanted to know about building and rebuilding engines in here! Remember to post your model-specific questions in the correct section.
Finding TDC
Old August 29th, 2018, 3:05 AM
Craig Small's Avatar
Default Finding TDC
I have recently replaced the freeze plugs on my '87 V10 5.7l and reinstalled the engine. I am trying to manually turn over the engine by the crank to find TDC but it won't budge and I am afraid to snap off the head of the bolt and create more problems. Does anyone have a suggestion as to what I should do next?
Old August 29th, 2018, 4:42 PM
kevinkpk's Avatar
Spark plugs out of it?
Old August 30th, 2018, 6:53 AM
Yeah I did that. Someone suggested that i try " bump starting " it but Im not sure what that is
Old August 30th, 2018, 11:54 AM
You bump start it with the starter. Just turn the key real quick and release so it just moves a bit.
