HP output
Hi Guys as i am a newbie, i need some advice regarding my 350 sbc engine build
iam am going to be using the following with my build pro comp 220cc heads, headset,intake,roller rockers 383 2 piece rear stroker kit , camshaft and lifters 600 cfm edlebrock carb push rods, guide plates, harmonic balancer Please advise if this combination will work and an estimated HP output Thanks in advance |
Sounds legit.
I'd throw in a high pressure fuel pump that monitors&controls flow. Sounds pretty sexy, but don't have enough info to get exact estimate. I'd say you should have no problem @500
