Engine Building & Overhauling All you ever wanted to know about building and rebuilding engines in here! Remember to post your model-specific questions in the correct section.
Need Gen 5 BBC info
Old October 17th, 2018, 7:45 PM
overdriv's Avatar
Default Need Gen 5 BBC info
I'm working on a GM 502 which I think is a Gen 5 version as it does not have provisions for a mechanical fuel pump.
I thought all BBC engines after the MK IV would have roller cams. This motor has a hydraulic flat tappet cam????
It also has a sheet metal MK IV like front cam cover? Again I thought it would have a cast aluminum cover??
In the lifter valley, what are the three cast in block bosses with plugs in them??
Can I use a gen 6 cam in the engine?
The block casting# is; 14096859 Mortec says; Gen 5 502
Head casting# is;14097088
I need educated on GEN 5 BBC
Any help is appreciated.
Old October 18th, 2018, 3:50 PM
oilcanhenry's Avatar
502 HO Tech Specs
  • Part Number: 12568778
  • Engine Type: Chevy Big-Block V-8
  • Displacement (cu. in.): 502
  • Bore x Stroke (in.): 4.470 x 4.000
  • Block (P/N 19170540): Cast-iron with four-bolt main caps
  • Crankshaft (P/N 10183723): Forged steel
  • Connecting Rods (P/N 19170198): Forged steel, shot peened
  • Pistons (P/N 12533507): Forged aluminum
  • Camshaft Type (P/N 24502611): Hydraulic roller
  • Camshaft Lift (in.): .510 intake / .540 exhaust
  • Camshaft Duration (@.050 in.): 211° intake / 230° exhaust
  • Cylinder Heads (P/N 12562920): Iron rectangular port; 118-cc chambers
  • Valve Size (in.): 2.190 intake / 1.880 exhaust
  • Compression Ratio: 8.75:1
  • Rocker Arms (P/N 12523976): Stamped steel
  • Rocker Arm Ratio: 1.7:1
  • Water Pump (P/N 19168606): Cast-iron, long-style
  • Flexplate (P/N 10185034): 14"
  • Recommended Fuel: Regular Pump
  • Ignition Timing: 32° Total @ 4,000 rpm
  • Maximum Recommended rpm: 5500
  • Balanced: External
Old October 18th, 2018, 5:31 PM
overdriv's Avatar
Thanks for the specs on a GEN VI.
I'm working on a GEN V.
