Engine Building & Overhauling All you ever wanted to know about building and rebuilding engines in here! Remember to post your model-specific questions in the correct section.
valve timing
Old June 3rd, 2018, 7:55 PM
jimmy70's Avatar
Default valve timing
i have a 77 454 i have rebuilt several engines but this one is giving me fits no matter what i do it is spitting the gas out the overflow of the carb every time i crank it over i have checked the cam timing . valve adjustment . and ignition timing
Old June 3rd, 2018, 8:39 PM
kevinkpk's Avatar
I know this is what you have checked, but recheck the cam to crank alignment
Old June 3rd, 2018, 9:47 PM
jimmy70's Avatar
I just finished pulling it down the there is only one key way and one timing mark but its about thirty degrees off from the harmonic balancer timing marks on the crankshaft gear
Old June 4th, 2018, 1:46 PM
kevinkpk's Avatar
Is this the same the first time you tried to start it?
