Engine Building & Overhauling All you ever wanted to know about building and rebuilding engines in here! Remember to post your model-specific questions in the correct section.
What is this 454 worth?
Old May 18th, 2011, 2:48 PM
davbell22602's Avatar
Default What is this 454 worth?
I found a 454 out of 85 burb 3/4 ton 2wd thats locked up for $175 complete.
It locked up from someone driving it and the trany got stuck in 2nd and engine being over revived from it.. I figure all the external parts are least worth the $175. I wanna rebuild it and put it in a gmt-400. The 85 burb is also missing a steering column. the guy said he can junk the whole thing for $600.
Here's pictures of the engine and burb.
Old May 18th, 2011, 3:09 PM
Reynolds357's Avatar
It all depends on what it looks like when you get inside. Most seized engines I have torn into have not been worth rebuilding. I will not rebuild anything that requires more than .30 over on the cylinder walls.
Old May 18th, 2011, 4:53 PM
I dont think the pistons are frozen. I think the crank bearings got hot when it was stuck in 2nd and reviving. Then when the engine was shut off then crank bearings cooled down and froze up.
core shift lsx 454
November 18th, 2012 3:35 PM
heavychevy511
Silverado & Fullsize Pick-ups
October 31st, 2012 8:43 PM
shipma2
November 29th, 2011 2:00 AM
woodstockaz
August 15th, 2010 4:08 PM
Quick Reply: What is this 454 worth?
