2005 Equinox lift gate will not unlock
Can someone tell me if there is an emergency release in this years model to open the lift hatch bc mine will not unlock. it is driving me crazy not being able to use mt lift gate!!!
The Mrs. (April 6th, 2021)
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> natwood68,
To unlock the liftgate, press the unlock button on the remote keyless entry transmitter twice or use the power door lock switch.
If normal operation does not work, it may be a lock actuator issue. I encourage you to have the vehicle inspected by a certified technician. They will be able to offer a more accurate diagnosis and repair options.
Please keep us posted.
Louis
GM Customer Service
Louis
GM Customer Service
Louis
GM Customer Service
Louis
GM Customer Service
The following 2 users liked this post by LOKL12:
The Mrs. (April 6th, 2021),
Walter G Dowak (May 1st, 2021)
the may be a round plastic trim cover near the bottom center of the liftgate, inside the vehicle. Pop the cover off and with a screwdriver, manually release the latch.
hope I'm not raking you over the coals.
What kind of forums are these? Take it to a certified technician? Ive been looking through forums for the last few days to try and fix this problem. A certified technician rakes you over the coals for repairs. Im sure most people are looking for some free advice on how to fix this vehicle that appears to have a ton of issues including this one. No manual ability to unlock the liftgate?? Really? The designer is brilliant.
ruley73 (April 6th, 2021)
Also, the 2007-2009 models do have a plug that you can remove for manually releasing the latch. The 2005-2006 models do not.
