2006 equinox heating up and nether fan will kick in.
If the fuses are good, check the temperature sending unit. One fan turns on when the temp rises above a certain level. The other one turns on when the A/C is on.
What does the temp gauge indicate when the engine is warmed up? Do the fans turn on when you turn on the A/C? Without the A/C being turned on, on our 2007 Equinox the gauge needs to get to at least the half mark before the ECM will activate both fans at low speed. The temp gauge on our Equinox rarely gets to the half mark. In the four years we have had it, I can probably count on one hand how many times the fans have turned on without the A/C being turned on.
Is it running that hot at highway speeds? If yes, you have bigger cooling system problems than cooling fans. At this speed fan operation is irrelevant.
The fans should be turning on low speed at 96 C and high at 102 C. Fan operation is controlled through the pcm. Check for dtc's first. If none are present check the low and high cooling fan fuses in the underhood fuse box. If they are ok check the low, high and s/p cooling fan relays.
2006 with fans not running at idle, temp very near red
Reading what is already posted, I have a problem with knowing if relays are good or not. They look fine? Where is temp sending unit and how do I check or temporarily by-pass to see if that is the problem?
Thanks for any help!
Kentucky Kyle
UPDATE-After seeing where one guy wiggled the wires at the fan I tried it and they both came on. What, if anything, do these connections have to do with the air compressor kicking on?
Kentucky Kyle
This is how I check the coil. With the circuit energized, pull the relay out, and back in you should feel the coil pick up, and contacts transfer. That however is not checking the contacts. if you have a voltmeter, put on lead on each side of the wires that go to the contact. if that part of the circuit is energized, and the contact is open, you will read battery voltage on the meter. If the contacts close, you will read 0 volts.
Official GM Rep
We're glad to hear that you found the course of the cooling concern you had been having, Sonicd! Many more happy miles!
Sarah (Assisting Louis), Chevrolet Customer Service
