2007 Equinox..HELP!!
3.4 lt...tempature gauge doesnt work,check engine light on,engine hot a/c off displayed on dash, both electric fans run as soon as you start the truck..also lower radiator hose cold after driving for 30 minutes..WTF!!! It was fine yesterday...any ideas?? "HELP"!!!!! Dave!!
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Dave,
Would you please tell me more information about the vehicle? How many miles are on it? How long have you owned it? I would like to check into some options for you.
Breanne
Chevrolet Customer Service
Breanne
Fixed
got it fixed yesterday..was the coolant temp sensor..put a new one in..had trouble finding one..went to dealer..$30.00 for the part...themostat and Dex Cool 2gals $40.00...so for less than a hundred we fixed it...took awhile after I poured the anti freeze in to get rid of the air in the system...bleeder is under the plastic cover front left side..drive it after you fix it..it will get rid of it...
Irunthesystem
Equinox
January 28th, 2012 2:32 PM
