2007 Equinox key fob
07 Equinox the Key fob works when parking and locking the doors. Twenty seconds later the fob does nothing unless you manually unlock the door and then silence the alarm with the unlock button on the fob. New battery on fob and relearned fob through car's menu still the same.
Originally Posted by Fox1311
(Post 226243)
Are these the original fobs or new fobs? Is this a recent issue? Did it start after changing the battery? Louis GM Customer Service |
Mine was acting up and I bought one from a seller on Ebay. I got an original GM fob with programming instructions. Works great! There are many of them for sale with much better prices than the dealer.
Originally Posted by Chevrolet Customer Service
(Post 226376)
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:DontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Fox1311,
Fox1311,
I have a Camaro and had similar problems as yours. Have you tried reprogramming your fob? That worked for me And please do not pay Dealers or Locksmith, they will just charge you to much. Instead you can look for a video on Youtube or google it. here is a site I just googled for you, hope it helps you out 2007 Chevrolet Equinox Keyless entry key programming instructions - ProgramKeyFob.com Danijal |
thank you i have tried reprogramming it
(Post 226243)
Hi! Where you able to find a solution to this problem? I'm asking because I've purchased a set of new programmable fobs and they worked for a while. Not long after they, like the original fobs, quit . |
