Camshaft for torque increase
I have a stock 3400 LNJ. It produces 185 hp (138 kW) and 210 lb·ft (285 N·m).
My transmission is an Aisin AF33 that has a gearbox limit of 243 ft·lbf (329 N·m) of torque.
I have been considering a few options to get a torque/HP increase. I would have loved to supercharge my 3400 but I cant afford a new tranny. Looks like a 20-30lb torque increase will have to suffice. I have considered porting/polishing my heads or a 3500 head swap.
Computer adjustments are NOT necessary with a new camshaft (so I have been told)? Basically I am looking for help to properly remove my old camshaft and install the new one. While I have the engine open are there any other parts I should consider replacing? Valves? Lifters? Head gasket? (my previous engine had a had gasket issue, among other things, leading to a tick, then blowing 6 months later despite all my efforts, hense my newer engine, that I have been treating very very well so I can do something like this).
If somebody has anything even close to a step-by-step guide it would mean the world. I guess this would be my first "engine job". I have a torque wrench and angle gauge for the cylinder head bolts.
Are there any other parts besides the cylinder head bolts I should consider replacing while I am at it? Head gasket? Valves? Lifters? (hydraulic, switch to anything else??), new timing chain? (and ofcourse new Comp Cams 26986 Valve Springs)
I am not trying to push crazy power out of the engine, I am purchasing the torque/MPG cam to help move the extra weight of my equinox. This is all for a learning experience. The fact that I can do it for $500-$600 is more appealing then trying to piece all of the parts together for a 3500 swap and have random parts and adapters.
If anybody has a better idea to get 20-30lbs of torque that is easier then a camshaft swap, I am all for it. I figure a camshaft swap is a nice step-by-step guide towards getting to know the inside of my engine, because I love every other bit of my car.
NOTE: this is my daily driver, so I need to do the job right. I will post pics and keep you updated, I need some input before I move forward with the job. All help appreciated
Its a 2005 with a 3400 LNJ. Not compatible.
I have looked into piggybacking, downgrading to OBDI or a 3500 swap. So far a cam seems the most reasonable (being one single part and not crazy expensive).
MathewsMan
Silverado & Fullsize Pick-ups
60
October 20th, 2014 11:39 AM
