Engine Power Reduced/Service Stabilitrac
I have a 2007 Chevy Equinox that is showing engine power reduced along with service stabilitrac. I was told to replace the throttle body so I bought a new AC Delco throttle body and replaced it and its still doing the same thing. Now on top of those issues it is now accelerating on its own.
Welcome to the forum.:) That sounds dangerous. What were/are the trouble code(s) that led you to the TB diagnosis? How about getting it checked out at the service department? The diagnostic fee is nothing compared to the possible damage you may be incurring?
I took it to get the check engine light read at autozone and that was the code given to me. I just cant bring myself to pay 100 bucks and then also pay more to replace more parts. the throttle body alone was 200.
Well, it's still not too late to get it diagnosed properly. Do you already have 100k miles on the odometer? Otherwise, the 5y/100k powertrain warranty may cover whatever the problem is. I think it covers things like the TB.
I agree with EinST, use that warranty if you got it....
I do not have warranty. I already have 126,000 miles.
Well, then, how about the exact trouble code(s) since I often find AutoZone interpretation to be misleading/misheard/misunderstood?
same thing
i have the same thing with my 08 equinox i just replaced the throttle body. (Autozone was out so i had to go to the dealer) $300 later still same thing. took it to the chevy dealer they erased the codes and the accelerator petal was showing a code now. another 65 dollers for that i hope it works ill post more if it fixes the problem.
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:DontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Fisher1089,
I apologize for this issue. Keep is updated. Breanne Chevrolet Customer Service |
Originally Posted by Chevrolet Customer Service
(Post 192659)
I apologize for this issue. Keep is updated. Breanne Chevrolet Customer Service Post what you found out. |
